How would this be put together? Would the hex-hub be glued to the Banebots wheel and then screwed to the output shaft of the gearbox? How would you fasten it with the reverse-thread screw?
Wheels to fit drill motors?
Using the hubs linked above on eBay?
I'd need to get my hands on them to be sure but the way I currently envisage it is:
- put an M10 penny washer on the drill output shaft
- screw the UNF hex hub onto the drill shaft
- slide the Banebots wheel - with corresponding hex hole - onto the UNF hub (I'd also make sure the hub is cut flush with the wheel)
- secure the hub in place with the M5 reverse thread screw and an M5 penny washer.
The purpose of the two washers would be to stop the wheel moving from side to side on the hub, as well as their standard washer duties.
Yeh that's exactly what I had in mind, I'd be interested to hear if it works!Originally posted by RogueTwoRobots View PostUsing the hubs linked above on eBay?
I will look into the hub idea, 3/4 ali or stianles hex hub with 3/8 thread and two circlip groves to fit banebot wheels, will need to speak to the guys in the machine shop.
if I could how many takers not sure on price would just be break even and a little for the guys in the machine shop
no promises yet
