Hi again everyone, it's that time of the week again, I don't know how to build things. Times like this I regret not taking engineering at Uni, but no matter!
First question is with the actual spinning element, I know the removable link and all that has to go in the axle with a full body (like Little Spinner's) but how would I get the outer shell to rotate properly? I was debating an axle like Hypno-Disc's (http://images.wikia.com/robotwars/im...Hypno_Disc.jpg) with the smaller diameter upper half, if you get my horribly poor descriptions, but the thing I was struggling with was how to prevent any friction on that ridge where the disc will rest - I'd assume some kind of bearing, but I'm not entirely certain on what the best idea would be... The post itself would be about 4cm in diameter, but with a 15mm-ish hole in the centre for the link, possibly. May increase both of those measurements if they prove to be a bit out too, I should add.
Second question along with that, would a wheel-based transmission work, like that on Gyrobot - http://homepage.ntlworld.com/steve-w...y/gallery3.jpg ? It seems like it'd be a relatively simple and effective way of turning the outer shell, only other method I would think of would be a timing belt on the motor and the disc, but again I don't know if that'd get a bit complex and unreliable.
The motor I was thinking of using was either this http://www.hobbyking.com/hobbyking/s...arehouse_.html or this http://www.hobbyking.com/hobbyking/s...tor_730KV.html - preferably the latter just because of the power behind it, but I don't have the right equipment for 11s brushless yet so I might be better off with the first motor I posted...
Thanks for the help in advance!
