Chris, what I would do is to drill some holes at the top end cap, say six 6mm holes - that will eliminate back pressure when you fire the ram ( the air on the top side of the piston is creating a restriction as its being forced out of the top port)
QEV on the exhaust is not such an issue as long as you have strong enough bungees to retract the ram. Have a look at the ram on my build, it has two ports at the bottom, one connected to the QEV/buffer (inlet) and a small one as exhaust.
