If you go for a valve similar to the one I linked it includes the solenoid, 12v dc.
No need for "big" pneumatic stuff shop, actually most of the parts you need are small. Ebay is the best place in my opinion for the best prices
You could use the same set up I use for a double acting cylinder...all you need is to split the supply to the buffer. So from the 5way valve connect to the QEV on the buffer and the retract side of the ram. You could add a QEV at the retract side to avoid back pressure when the ram extends...
					Originally posted by Eventorizon
									View Post
