I have some more questions I could do with answering if anyone has a minute. I've tried to save them up so as to minimise the chaos, have searched for the answers but haven't got the specifics I've needed. They're a bit general...here we go...
1. Is it feasible to do a whole event with a feather on one big SLA? My simple pushy robots never weigh much when finished (circa 8-10kg) and have low powered motors. I was umming and arring about sticking a ginormous SLA in that's rated at say 12Ahr and seeing if I can just turn up with robot and toolbox and have an easy life.
2. Cradles...is something like some 2x2 nailed together suitable as long as it keeps the wheels off the table/bench/ground etc?
3. Wheelchair motors for a featherweight axe. Originally bought a wrecked wheelchair for the running gear to put in a naff heavy weight. At the time I just bought the chair on a whim as it was going to the scrapyard the next morning if not. Since dragging it home, stripping motors down to remove magnetic brakes etc I've become disillusioned with the cost of building a heavyweight. I was looking at ways of re-purposing the wheelchair stuff (bearing in mind each motor assembly is around 7kg) into a feathereight. Would it have enough torque at 250W to roll a hammer-bot back onto wheels if I make the body a low curved shape etc? Am I better just giving the wheelchair to a builder who will make better use of it? Should I save up and have a crack at a cheap heavyweight?
4. Bigger wheels with 3/8 unf thread. I've had a mare trying to build within the confines of 100mm blue wheels. Does anyone know of anything bigger, say 200mm with a unf thread? I'm umming and arring about making my own wheels e.g. 200mm hdpe circle with 8mm hole drilled in the centre threaded onto chuck output shaft, bike tread screwed on. If anyone has found anywhere doing big wheels please lemme know / discuss / comment better way of making home-brew wheels.
5. Based in Blackpool. Any other builders with something running from the Fylde / Preston area fancy meeting for a car-park street-fight / generally getting to know some fellow builders in the area to swap parts/knowledge? I know the Big Nipper team are from up this way but so far have been too shy to get in contact. Email to The Jammy One yielded no results (don't think he's been on-line for a long time).
6. Fail-safing Tx/Rx combo. Back when I was getting sorted with cheap everything to get up and running all I could afford was £20 Giant Shark handset. Since now realising it doesn't failsafe all that well, and having tried a posh external failsafe with no joy, can anyone recommend a nice set that failsafe's on all channels. I have around £100 to spend and am seeing this as an investment. At the minute the hot favourite is a DX6i with an Orange Rx. Please can someone with experience of these confirm they do failsafe all channels to a neutral position. And if so, which specific model numbers should I be watching out for?
Thanks again.
Dangerous Dave.
Thanks again.
Dangerous Dave.
 , so if you're going down that line then you'd want something lighter. Jamie's had a battle getting Onyx in weight and using a Li-Po it scrapes in at the weight limit (sometimes). Like I said before though, if you're not entering it into the UK Champs if its a few grams over weight it won't matter too much, especially if you have all of the stuff you want to use sitting there already.
