hi all
i am wondering if their is a recomended thickness for buying sheets of hdpe to build your bot so that it might survive more a couple of fights atm im looking at 30mm sheet with a sacrificial layer of aluminium on the sides to give me some defence against spinners but any advice on the matter will be appreciated
 . Explosion, for example, only uses 4mm HDPE (I think) but is mounted on a hardox welded frame. I would probably say that 30mm is a tad excessive though, not sure though.
