just had a quick glance at some other threads and couldnt find anything much about polyproplyene, so ill just ask here.
im looking to change my bot cobra over to a different material for its lid, as its been using 10mm lexan and i had a massive split occur straight down the lid when a spinner hit the side (didnt even touch the lexan itself).
i was thinking polypro would do the trick as ive heard it is good for robot use, but i need a bit of info that has been hard to come by on google (probably because of my half-assed searching
* what is the density of polypro approximately? im hoping that its around the same as lexan
* ive read that polypro can be bent back and forth repeatedly and not fatigue, is this true?
* is polypro clear to radio signals?
* is polypro harder than lexan?
AND * is there any little quirks to working with the stuff, eg does it crack, does it deform easily..
oh yes and finally how does the stuff stand up to axe bot attacks
any help greatly appreciated.
