Sabertooth 2x25a Problems??
    Can I buy them from the UK?
      No you can't.
      So, is this speedo being used for the old house robot or not ? You say this machine is 100kg. Anything that size needs some serious motor to move it, the Scorpion XXL will blow up if you hooked it up to anything that size.
        Ok, so what is the next step up? And preferably from UK?
          4QD should run wheelchair motors nicely and their based in cambridgeshire
          they even do a rc interface
          http://www.4qd.co.uk/accs/dmr3.html
            Yes they are cool but £400 bit pricey lol
              This uses A Sabretooth 25A On 24v or 12v Weight well over 60Kg! Never missed a beat. It's often down to gearing and design.
                if your running 2 24v wheelchair motors on 24v you should be on with 2 of the vtx 40 controllers which are like £85 each or unboxed £66 each
                • #23
                  is this going to compete or be pushing any serious weight other than moving itself about
