Removable link mount
I know there may still be better ways of doing a removable link than a Deans Connector, but everything I've built for my robot so far revolves around this. If you are still making them with a Deans I'll have a few off you as it's another pre-built bit that I don't have to worry about.
It's people like you, Ewan, the Robochallenge guys, Dimension Engineering etc and the members of this forum in general that have made it possible for someone like me to have a bash at building a Robot.
Lot's of robots lost fights because their links fell out, which is a really crap way the lose, but it happens far too often!
I'm not sure deans are to blame, but I will say the tabs do wear flat over time and the link becomes loose so be weary of that.
Simply because of their current capacity and the amount of friction there is in the design to stop them coming loose I would design for EC5's
Of course nothing is 100% gaurenteed to work but I beat Nightfury by knocking out its link and several others lost this year for the same reason.
Then again with a laser cutter you could do one for each kind with no problems at all!
