DX6i mixing
  • DX6i mixing
    i think this is a common problem but i am wondering if people can help me with it. Im using a DX6i with the ELEVON option selected. To counteract the 50% throws and get full speed/ power, ive used the following youtube tutorial: http://www.youtube.com/watch?v=6Ewa79_9Iq4
    The bot, which uses two self-hacked 85a ESC, works perfectly fine until for example you push the stick above 75% forward and 75% left, expecting the bot to start turning as the left side of the drive slows down and letting the right side bring the bot around to the left. At the moment, its doing the opposite in this situation and bringing the bot around to the right. it works as intended at lower speeds and when using the ELEVON option on its own without the messing with the 50% throws.
    Cheers
    Dan
    Re: DX6i mixing
    is the servo reversing in the right position?
      Re: DX6i mixing
      yup! theres no servo reversing in use as ive wired it up so it wasnt needed.
        Re: DX6i mixing
        I have a similar issue. I get full throttle forwards but only about 25% throttle backwards on Binky. Thinking of buying an external mixer, I already have one from The Robot Market Place, XR1... i think
          Re: DX6i mixing
          ive tried an external GWS mixer and its still the same problem. i think its a common issue but there must be a way around it. I've got a plan B which involves tank steering so gonna look into that too
            Re: DX6i mixing
            I would check your travel adjusts, navigate to travel adjusts and check all the numbers are at 100% then move each stick forwards then backwards then left then right to make sure the values don't change, I have problems before whe I had a Travel adjust in direction and not the other.
            With my dx6i I haven't had any problems with the mixing.
              Re: DX6i mixing
              I don't think there is anything wrong with the mixing but purely using the ELEVON function means ull only ever go 50% of the possible top speed. Using the mixes 1 and 2 means you get the 100% throws but it messes with the ELEVON function.
                Re: DX6i mixing
                correct same issue on my robot , used mixing built into sabertooth to fix the problem
                  Re: DX6i mixing
                  I'm thinking there must be a way of doing it. Im pretty sure my Tx did use to do it anyway so god knows whats changed.
                    Hi everyone,
                    Ive now tried everything to sort this problem and made little progress. The Botbitz ESCs shut down if the travel signal goes over 100% (i dont see why it couldn't have been programmed to just stay at 100% instead of doing that but anyway) and when i use the mixing above in the DX6i, it sends the travels way over this. Using the travel adjusts doesnt seem to limit the mixing for some reason. All this has been tested on a brand new Tx which i bought today.
                    I've tried the hobbyking T6A-V2 system which the botbitz ESCs were built around but there is no way of telling whether the motors are going 100%. The mixing on them is a little obscure as well but i was able to use the system at Burgess Hill but it really bugged me that i never knew if it running to its full potential.
                    If anyone else out there uses a DX6i and botbitz ESCs, may I ask what mixing you are using?
                    Also, what other Tx, Rx and maybe external mixer set-ups people using with the botbitz ESC which seem to work fine? (failsafe, doesn't do anything crazy with the mixing etc)
                    Cheers
                    Dan
                      A fairly crude way to know if you're running the motors at 100% would be to put a battery onto them directly, listen to the tone, then do what should be full throttle on the tx and see if there is a marked difference in the sound.
                        Tried that and it's very difficult to tell the difference. I also tried putting a multimeter on the motor terminals to compare the voltages being sent to the motors but at the higher end of the throws, it goes crazy and can't seem to measure it. What Tx and Rx set up do you use on Tormenta 2?
                          If you can't tell the difference in tone between the battery directly onto the motor terminals and going full throttle at the transmitter then chances are you are getting 100%.
                          We use a Planet 5 transmitter and receiver kit, a v-tail mixer, and the Botbitz. Very simple, only complaint with the tz85s I suppose is that when you put the stick fully into a corner of its travel, it doesn't move. I assume this is some sort of mixer+tz85 combined issue as it didn't happen when we used to run electronize. It's not a problem in the arena, really, as you rarely want to do donuts anyway. :P
                            We use DX6i's and Botbitz on both our machines. As I said before, the only issue we have is that it goes faster one way than the other.
                            The mixing is set to Elevon. We have one channel reversed as I prefer to wire up my motors so that I have the positives on the same edges as the motors so It makes it easier to see the flow of power through the machine.
                            The Big Nipper guys messed with my TX at GSL to sort the speed issue with Conker but that was it, Speed only.
                            Try rebinding the RX with everything reset to defaults then edit from there. If you edited before had then it could have given the RX and ESC's false centre points or something... no idea really, just a thought.
                              Using purely elevon on a dx6i limits top speed in forwards and backwards directions to 50%, and will only reach 100% if spinning on the spot which on a rambot isn't what you'd want. It might be that I may have to upgrade my Tx to a more adjustable unit.
