Battery capacity
  • Battery capacity
    Hey guys, been looking at batteries and need to know something
    Im needing to run my drive (2 drill motors) and weapon (A28-400 mag motor) off a single battery pack due to space inside the bot
    Will only be running at 18v (Dont be too scared, only then 3ish bhp behind the disk) but not sure whats the smallest sized pack I could get away with
    Currently running 3700ah and im not sure that will be enough to last a fight, would you say it will alright or will I need larger capacity?
    Re: Battery capacity
    Should be fine. Just make sure your battery pack is able to deliver the current that the mag will request
      What did you run your mag on in hornet 2?
        24v nicads then A123s. Lipos weren't really around at that point
          I ment capcity wise
            2.4Ah or around that mark. Never used more than 1.2Ah in a fight
              Think ill be fine then
                What battery type are you going to use? Your options are pretty much only LiPo with a magmotor, unless you use loads of cells of other types, but you're going to have serious weight issues if you do that, soo... my point is, make sure you use a LiPo that will happily dish out what the mag will pull, or it will not be happy.
                  Im going to pretty much drum the rest of my cash into this feather, bulldog will have to wait as I want this done well
                  Ive not nimh's of around that capacity but wont be using them, can only give 30a
                  What brands would you say are good to use? And recommend a good charger for them as I know some can be dodgy but you need balencing etc
                    I'm not your guy for recommending brands, I'm just glad you're not going to try and use NiMHs.
                    Hardly your guy for recommending chargers either, as we have only used one (not including our own efforts), which is the accucel 6. We have no complaints, and I know many others use them.
                      being a person which uses lipo's all the time in various projects, there is only 2 options at the moment either optipower or thunderpower ( We get 30% discount on optipower if fra member)
                      charger wise cell pro 10s, power lab 6 and power lab 8 , you can buy other chargers but no where near as good ( also 30% off if fra member)
                        Whats the objection to nimh/nicad packs again? They were used once so I see no reason why not again but im sure im missing something
                          Well you can't buy nicad anymore and Nimh can't supply large enough currents, weigh more than lipo and you need lots of em to power a bot.
                            We had to double up our NiMH packs to give Tormenta 2 what it needs, and even then I suspect we'll see a boost in performance when we go LiPo. That's 4 standard drills and a weapon motor smaller than a s900. Your mag could probably pull more than our whole robot, lol.
