I have ALOT of polycarb about ranging from 6-10mm but what would this be like for armour etc? Not too sure how it would compare to nylon and hdpe
Polycarb... opinions?
Re: Polycarb... opinions?
Kind of of this subject...
What exact type of polycarbonate is what we perceive as 'Polycarbonate'?
In this material selection softare (CES Edu Pack) I have about 60 to choose from.
There are glass filled, graphite filled, stainless steel filled, several others and Unfilled. Unfilled has the lowest UTS but it is perfectly translucent.
I need a type that is perfectly clear but has a high UTS and toughness value. Unless someone can think of another material that fits that bill.
I used polycarb bolted to box section. I shock mounted it using thick rubber spacers, sometimes a spinner would take chunks out, other times it would shatter, personally I would go with hdpe, if I used polycarb again it would be only for extra bolt on armour over hdpe, and that's only if I had some lying around spare
