I have a few questions I wanted to ask with my last few queries so that I can hit my target of getting finished for the spring. If anyone can answer one or all of them I'd be most appreciative.
1. Are Giant Kod Radio's for forty quid any good? Will it work ok in The Roasting Dish of Doom? Has anyone tried one and found it to jump, skitter, lose signal, get interference etc? The final part of this question is will this radio setup work ok with my 2x12 Sabertooth?
2. I want to use double sided sticky foam to stick my receiver and Sabertooth to the bottom of the roasting dish. Does the metal surround of a Sabertooth act as a heatsink thus making this a bad idea?
3. Which events out of all of them do I need to enter to prevent my robot getting smashed to pieces? This is as in which event can I enter that won't have spinners and other mental robots around where I can just learn the ropes?
4. What is the most common way of making the required removable link and LED, and where can I buy these from?
5. Is there a calender put together of all the yearly events from all of the different organisers so I can see at a glance a chronological order of the combat year? If not would anyone be interested in me posting one if it doesn't already exist?
6. Can anyone suggest a crazy powerful pre-build motor and gearbox combination in the same vain as Gimson's that an idiot like me can prepackage into their own body? I'm looking for Speed 900 power without the faff of trying to make a gearbox.
As a final note, to say thank you for any help given by everyone over the last 6 months I can probably answer any of your pc/laptop/server questions and suggest courses of action or give recommendations and to a possible solution.
Thanks again in advance
Dangerous Dave
Dangerous Dave
