i was thinking of up grading to a lipo, and was wondering whether people thought its better to get to smaller battery's and swap every fight (charging the one that's not in the robot), or one big batter than can last multiple fights? so charge it less often, when we have time.
Because with a NiMh or lead acid is a no brainer, get a larger batter ( that you can fit in the weight limit) and then top up between fights but never remove it.
But with lipos you have to remove them to charge them, and that takes longer,so i cant decide whether to get two like 5000mah lipos which might just last two fights (i would fit telemetry system to tell me how its going) or 1 8000mah battery which should last for like 4? the 5000mah seems the better idea as its lighter and we can swap them between each competition fight, but i would have thought a 8000mah battery would be better for white boards as it can be run continually for a few battles?
i cant decide what to do? both a similar price
any thoughs?
(i was looking at the turnigy nano tech batterys by the way, http://www.hobbyking.com/hobbyking/stor ... Order=desc
so was also wondering how they faired?)
any thoughs?
