Ampflow E30-150 for a spinner
    Re: Ampflow E30-150 for a spinner
    Oh, I'd have thought big overdrive is easily possible, with that much torque.
      Think the fact heavies use them for disks, I could go with an increase but then how much?
        put it on a 1:2 or 1:3 ratio. The big magmotor is pointless as you will waste so much weight in the motor. Oh and to handle the torque you will need to make sure that you have heavy duty belts or chains to handle it
        Mind you back in the day I had hornet 2 on a 1.8kg disc with the mini mag. Worked fine on a 1.5:1 ratio.
        For a brushed motor I'd just go with a big solid state relay. Don't bother with a controller as it will fry unless severly oversized.
          Got the relay sorted
          Will either go buy some large belts or use some of the same chain that I use in bulldogs drive, got plenty of it
