Speed 900 Alternatives
  • Speed 900 Alternatives
    Hi
    After finding out that the Graupner Speed 900's are no longer being made, and failing epicly at trying to find any alternitives, does any one know of any motors with the same kind of specs.
    I am getting kinda desperate after spending a good couple of months designing a half decent bot using Speed 900's
    Thanks
    Re: Speed 900 Alternatives
    Actualy, the Graupner Speed 900's are Johnson 51mm diameter motors.
    Several variants are available trough Ebay.
    Also, as long there isn't a disk or axe slicing trough the motor, for drive those are rock solid.
    Afters 9 years of hard use , I know of 2 failures of a speed 900 or equivalent motors in a drive application.
    1) Hannibalito 1, because Little Hitter dented the body and broke the magnets.
    2) Plofbox II after a meeting with Hornet II. The axle was bent 90°.
      I managed to nacker one in bonx when i drove it but then I'm not used to single stick
        They have stopped producing S900's! Why is it that everything in Conker II is slowly being replaced... no I have no drive or weapon replacements!
        Looks like I am going to have to go to a HK-50...
          Like these ones: http://www.ebay.co.uk/itm/Johnson-60...item19d5340368
          They seem more like the Speed 600 specs though
            Getting closer but still not the same
            http://www.ebay.co.uk/itm/13000RPM-Outp ... 5d36f9b8f6
            http://www.ebay.co.uk/itm/Toys-Moulding ... 53f0c29099
              I am thankful I have 1 spare at least :P
              My only failure with a 900 was burning one out at the UK champs in 2010, but that's because I was running it when it was being resisted for about a year.
              Well, I better get searching for alternatives.
                4 hours to go. Let the bidding war commence :P
                http://www.ebay.co.uk/itm/Graupner-Spee ... trolled_JN
                  I think I'll cling to my supply... Sooner or later A speed 900 will be worth it's weight in silver.
                    Some interesting discussions on speed 900 and equivalents
                    http://www.modelboatmayhem.co.uk/forum/ ... ic=19413.0
                    and
                    http://www.modelboatmayhem.co.uk/forum/ ... ic=32751.0
                      Have a look at things like
                      Johnson HC987LG
                      http://www.johnsonelectric.com/en/produ ... metric.pdf
                        That is the motor Graupner rebatches as a Speed 900.
                        Now it's the question, will Johnson sell these motors directly to the roboteers or a shop that caters to us?
                          So, 6 months on, how are people getting on.
                          Anybody found anything yet?
