I recently bought some cheapy ESCs from eBay which work fine except for one thing. There is a 1s delay when changing directions, which although sounding insignificant actually makes it impossible to drive!
Guilherme (Galactus) uses the same ESCs and doesn't have this issue so thinking it must be something my end I have swapped, changed and eliminated every possibility I can think of to no avail, so thought I'd open it up to the forum.
What I've done:
There is no delay on a servo.
Changed The Rx and Tx to a different brand.
Used an external Rx battery instead of the built in BEC.
I have stripped the system down to it's most simple, then complex and everything in between to see if that could make a difference, but nothing.
Any ideas?
What I've done:
Any ideas?
