Leverage ratio dilemma
  • Leverage ratio dilemma
    Hi there, got a question regarding positioning and sizing of an actuator in a FW system. Some time back I had asked around for advice on how to make an LP system more powerful, and the general advice was that a large bore, short stroke cylinder placed as close as possible to the flipper arm hinge is the best solution.....viewtopic.php?f=111&t=5531
    Now I have been using this calculator viewtopic.php?f=111&t=5531
    Re: Leverage ratio dilemma
    A 63mm bore 73mm stroke ram has 0.23L volume.
    A 80*40 ram has .2L volume.
    Difference 0.03L = 13% less.
    I think we found the problem
      Moving the cylinder closer to the hinge will make the flipper weaker on the end of the arm due to the lever ratio.
      The main reason people say, large bore, short stroke cylinder placed as close as possible to the flipper arm hinge is the best solution.. is placing it close to the hinge to compensate for the shorter stroke giving you a shorter flipper throw.
        I think the main reason for increasing power and moving closer to the hinge is because the tip of the flipper arm ends up moving faster. The extra power is needed because the ratio change makes it harder to lift a weight at the tip of the arm. The side effect of moving closer to the hinge is that you'll need a shorter stroke for the same amount of lift at the front.
        The result is an equal amount of lift power but a faster firing flip, so the enemy will get more air.
        You could have a very weak ram and put it as far away from the hinge as possible and still be able to lift another robot, but they won't fly, because the weapon doesn't move quickly. Your goal is the opposite of this: move it close to the hinge and the tip of the flipper moves quickly but your max lift will be hurt, hence why you need a more powerful ram to make up for the ratio loss.
        I think I just repeated myself, but oh well. I don't know anything about pneumatics anyway, don't know why I'm here!
          I totally ignored the change in volume!
          So if the volume is kept at 0.23Lt by increasing the bore to 85mm the throw will increase to 0.9m, to be honest its not much of an improvement :|
          The speeding up thing I don't fully understand as well, its true that the tip will move faster by placing the cylinder nearer the hinge point, but the added mechanical disadvantage will slow it down...I guess
            By placing the ram near the hinge you can afford to have a shorter stroke and larger bore- this mean the ram is shorter so it fits in a less tall robot- that overcomes your need for a telescopic ram.
              Not much op an improvement? Without using more CO2 you have an increase of 5%
              As the calculation shows, getting it right with a short fat ram is a marked improvement compared to the long stroke ram
                I don't know how well this works in practice as I have never explored this area, but it makes sense in my mind. Someone please tell me if I'm wrong.
                Yes the added mechanical disadvantage would slow the weapon back down under heavy load, which is why you need to have the more powerful ram.
                I made a really (really) crude animation to badly demonstrate what I'm on about.
                http://www.fileize.com/files/50d44066/abe/Flippers.swf
                Again someone step in if I'm feeding false information, I'm learning too here.
                  The link doesn't work for me, so the information that there is an animation there is false
                    The website actually died overnight! Just my luck...
                    Alternate link: http://www.fastswf.com/XvyjN_4
                      ok, I think I understand something now... had to find my old drawing board and loosen the rust off my engineering drawing - now I think I have a clearer picture of what's going on (I hope! ) What Leverage ratio would you go for?
                      My other question now is how large can I now go with the cylinder? The volume of the one I currently have is 0.23L with a 0.51L buffer tank (its a 12oz paintball bottle)
                      What's the recommended cylinder to buffer tank size ratio?
                        Industrial guideline is 5 times user volume. But I feel that a 3 times used volume is the lowest that yields enough advantage.
                          You do know that a paintball bottle is way overrated for a low pressure system- you could save a lot of weight by using a more suitable bottle eg. A small powder fire extinguisher
                            Hmmm, so I'll have to get a larger buffer... I'm already off the x3 mark with the current set up - so increasing the size of the ram will only make things worse :|
                            I opted for paintball buffer thinking they were light and compact, the 12oz bottle weighs about 600g, a 20oz one weighs approx 850g... so how much would a similar sized powder extinguisher weigh?
                              In theory less. But unfortunatly, 2 things are annoying.
                              1) most powder extinguishers are made from steel. Still cheaper to make.
                              2) with a volume of 1.5 liters , even a 1 kg model (from a car) is way to big.
