hi i am planing to build a featherweight soon amd i was just wondering weather a winscreen wiper motor was capable of lifting a 12 kg robot at the other end of a 50 cm arm or would a reduction gearbox be nececary also how would the plastic gear stand up to the punishment that a lifting arm would suffer as i could probably get a metal one made
Wiper motor lifter
This topic is closed.
Wiper motor lifter
An extra gearbox would certainly be required, and with the stress the gearbox will go through, all metal gears will be needed. The rpm of a wiper motor, although very low, is still far too fast for an electric lifter/flipper. You should be aiming for about 20-40rpm Output after the second gearbox. This would make the arm travel about 120 degrees in about a second.
Windscreen wiper motors vary in speed and torque though, so i cannot say any more.
Wiper motor lifter
The simplest way would probably be to use a threaded rod, like the Australian robot Blade. Windscreen wipers are still far too weak though, so a cordless drills might be a good investment.
http://robowars.org/teams/rotwang/blade/blade.htmlhttp://robowars.org/teams/rotwang/blade/blade.html
Wiper motor lifter
nope, we used window mechs in Flybot and Gladiator at RWE2. They used the standard motors, we ran them at 24v. They move through about 90 degrees and have more then enough power (ive got a pic of mine lifter on of our armchairs in the living room!). My arm was about 50cm long and could easily lift 12Kg at tip.
