Kinetic Energy Flipper
  • Kinetic Energy Flipper
    Had this idea in my head for a while...
    What if you used a spinning flywheel to store energy in a robot and then via a clutch dumped all the energy in to some kind of flipping device? It has probably been done or looked at and then discarded but the only issue I can see is building a strong enough clutch.
    It could be as fast and as as strong as a pneumatic flipper but not have the issues of running out of gas. The same could go for an axe weapon.
    Thoughts?
    Re: Kinetic Energy Flipper
    Has been done more than once with quite a lot of success. There is an american builder who I believe has 2 automatically-triggering flippers on his FW (for DragonCon). It works well, it seems. Then again, full machine shop tools help a little!
    And I think it was Ewan experimented with this in a BW-scale axe. Again, had good results, lots of power.
    Edit: the American machine is called Overthruster. I'll let you do the YouTubing.
      Team whyachi built a very nice machine. Full bodied spinner with an eccentric ring on top. The mechanism engaged and transferred all the energy into the flipper. Would be a bugger to machine though!
        That Overthruster thing is cool! How on earth does it work though? Its got some serious kick to!
        Edit: Didn't take long... http://www.wa4dsy.com/robot/overthruster-robot
          SKF Warrior
          http://www.youtube.com/watch?v=zs36Lv8P_1o
            What a crazy but awesome idea!!
            The over thruster guy has loads of info on his site and several different ke flipper designs. The best of which seems to work on a dog clutch.
              He has a new one based on an exponential threaded screw which seems to work very well and is much less complex... its just manufacturing an exponential screw that is the problem.
                I like the idea of innovation in robots but it seems alot of work to get something which to be honest is worst than a simple 1 burket FP co2 system
                  Hi,
                  please excuse my bad English. It is not easy to build a kinetic flipper. I have built one 6kg bot ala team whyachi. See the image. Without a lathe and milling machine it won't work. My bot / the mechanic was to sensitive in a real fight . So.... whopper Mark IV no longer exists. Perhaps, however, you could do it as a featherweight.
                  If you need, I have a few pictures of team wyhachis robot
                    Any vids of your robot (just out of curiosity?)
                    I'd be interested in seeing more picks of Team Wyachi's machine.
                      Images and Vids would be brilliant! We may have more luck at 13.6kg too.
                        Here is a video with whopper
                        http://www.youtube.com/watch?v=7H1H6L7bXxc
                        and the pics of skf warrior
                          pic 2
                            pic 3
                              pic 4
