Compressor-based flipper
    Re: Compressor-based flipper
    http://www.ebay.co.uk/itm/290555767209? ... _500wt_924
    the best way ive found so fat to connect to the buffer tank
      Gents by all means experiment but when Mario and Alan (both of whom have built several pneumatic machines) are telling it won't work and no other machine in the arena has used such a system in years you have to start to wonder if you are flogging a dead horse.
        Basically it is only a matter of time. If you get the time to bring your tank up to pressure it makes no difference if the pressure came from a bottle or a compressor. The only problem is that time is a luxury most of us do not have while in the arena. Getting your gas from a pre-filled bottle makes life a lot easier.
        I know of only 1 robot that still uses a compressor, and it is at best to be called a lifter. It is one of the German machines. It works, but selfrighting is a nightmare and takes way to long if it works at all.
          What is the advantage of having a compressor?
          Seems a bit like going into the arena with flat batteries and charging them while there, only you also have to carry the additional weight to charging equipment......
