This might be a stupid question but would it make sense to use pneumatics to power a crusher? I guess if it did make sense then other people would have thought of it by now.
Using pneumatics in a crusher?
Re: Using pneumatics in a crusher?
Its just the principal, Pneumatics are to quick for a decent crusher and as you know air can be compressed. If you have the knowledge to make a pneumatic system then you might as well make an axe-box. It would be great to see another and would be just as damaging as a crusher if you build it right.
Depends on budget.
I'm thinking about the Gimson Linaks
It's what I would buy when needing an electric linak.
Originally posted by teamkennyAlso something to think about is the pivot ratio with crushers, you can easily get half or even a third of the power of the linear with just having a long stroke claw
By the way, has Venom had any relative success in competitions at all?
Leverage is the main thing.
To put it simple. If the linak delivers 100 kg over 200 mm, the claw will deliver 100 kg if the movement is also 200mm.
You can exchange power for distance.
Linak 200mm movement/100kg
Claw 100mm movement/200kg
Of course, geometrics are annoying things, and if the robot hasn't a good design, the forces won't act as you would want, and then you're trying to rip appart your robot.
btw, the most powerfull pneumatic ram in a feather is probably Kennies Flow.
Originally posted by kevinOriginally posted by teamkennyAlso something to think about is the pivot ratio with crushers, you can easily get half or even a third of the power of the linear with just having a long stroke claw
Venom is good but is limited to what it can damage only being electric leadscrew, it also takes alot of power to crush through anything if you think cobalt runs 1600kg ram thats 4 times the power of the most powerful linear gimsons sells and that stuggles to damage something which is braced behind it
[attachment=0:3bgsf9ct]IMAG0283.jpg[/attachment:3bgsf9ct]Attached Files
I think the most important thing in a crusher is a front wedge that can get under anything and the drive system to back it up.
Once their wheels are off the ground, and that claw comes down, if you can move them around you're in control.
30s pin time, 3 min match, proves a good design for a winner.
Cobalt is an excellent example of this (although how you never got flipped Kenny I'll never know, jammy bar-steward)
Originally posted by teamkennyOriginally posted by kevinOriginally posted by teamkennyAlso something to think about is the pivot ratio with crushers, you can easily get half or even a third of the power of the linear with just having a long stroke claw
[attachment=0:g13q9v5n]IMAG0283.jpg[/attachment:g13q9v5n]
Its at 12.2kg at the moment all in with a 5000mah lipo which is over kill, only run the jaw a few times a fight, using a pair of RS550 drive motors so it doesn't use alot of battery power, i could run on a 2500mah if i wanted to loose some weight
Originally posted by teamkennyIts at 12.2kg at the moment all in with a 5000mah lipo which is over kill, only run the jaw a few times a fight, using a pair of RS550 drive motors so it doesn't use alot of battery power, i could run on a 2500mah if i wanted to loose some weight
