Re: First featherweight!
Gimsons arrived a few days ago, and botbitz ESC's have been ordered.
In terms of battery I was looking at either Opti power LiPo or a cheaper (local) alternative
Otherwise two 9.6v NiMh packs from similar to this
I would prefer to voltage to be above the 14.4v of the Gimsons so I get a bit of extra speed/power. Also for either option could someone please recommend a good charger/balancer, thanks!
For a base plate I may use thinner HDPE (6mm) as there's less play room that I thought between the Gimson's plastic mounts and the 78mm wheels! I may purchase a couple of 100mm robochallenge wheels for this reason.
