Hello!
I'm in the process of designing and building my first FW bot, but am unsure of how to put the chassis and armour together. This may seem a very fundamental (maybe stupid) question, but what is the best way of cutting the edges of HDPE (or any plastic) at any desired angle?
Basically just how to seamlessly join two parts together like a mitre joint expect with angles other than 45 degrees. I was thinking of using a tabletop circular saw I have but I believe I need a different blade to cut plastics, also I was considering a router or dremel with an angled bit on it. It's most likely going to be 10mm HDPE for the entire bot and I was planning on tapping the plastic so I can use regular bolts.
Thanks in advance, Dan
