Motors And Victors
Your comparisons are at the least, dated, ni-mh is almost at a par with ni-cad weight-to-current ratio. Your comparisons also dont allow for specific run time, you should allow for a 6 minute run time in the least (also 6mins is a 10th of an hour so it makes calculations easier
GP ni-mh cells at 3300mah (and other international other brand cells) can Peak 100amps, and not your suggested 60
Also, you need to take into account the actual energy capacity, and not just the short-period output ability. An EV may take short current spikes, but good quality ni-mh cells can cope with that.
(the debate continues
