Which regulator?
    Re: Which regulator?
    Paintball bottles have an output almost 1/2 bsp, trev regs come wit a co2 nut. The co2 nut is larger than 1/2 bsp and connects to standard co2 bottles.
    Archie, he has stated that he is building a lp system, also fp systems do not use regulators. Trevor's regs at just regs not valves, I'd suggest you do some reading up on the subject before giving out advice.
      this
        Chris:
        Hey, and welcome to the forum
        I know you may have a max limit of 17kg but if you can build it to 13.6kg then you can come and compete with us sometime. a 13.6kg robot can still beat a 17kg robot
        Do you have an actual arena to contain the robots ?
        If I was going to take pneumatics advice, I'd take it from Mario (Maddox) or Mike Lambert. Don't take too much notice of Archie.
        Archie:
        You've never built a pneumatic robot. Why are you giving advice on something you have no experience with ?
        Also, don't post that video of Satanix ANYWHERE. Use one where I ACTUALLY get to fight.
          Paintball regulator;
          http://www.ebay.co.uk/itm/NEW-PAINTBALL ... 2a1dff3251
          you could probably find your self one on ebay in your own country though, save on postage...
          that valve would work, for a basic low pressure setup, get a 3/2 sol/spring valve if you dont need powered retract,
          5/2 sol/spring if you want powered return.
          Also make sure you pick one up with either a 12 or 24v solenoid- dependant on what voltage you already have in your robot.
          Need anymore info- its best to find someone who talks sense and send them a PM. Theres a lot of mongs on this forum now.
          btw- Whats wrong with the video Weston?
            They exist?! :shock:
            And they've got an arena, you can see it in the video he provided a few posts back.
              Wow! thanks for all the feedback its all appreciated...
              David, will try to keep weight as low as possible but I doubt I would be allowed to participate with you guys as our rules are different eg we're allowed to use Lipo batteries etc.
              We got an arena, but maybe it will need to be a bit bigger and sturdier this year as the bots are improving year after year.
              As I've said earlier I'm using a Low press system - I'm not going to build a custom actuator for FP and anyway I'd rather go step by step. Think it will get too expensive for a FP.
              The 5 way valve is rated at 8bar working press but the max press on most of them is 12bar. I'll take a gamble with it and see what it can do (its not expensive anyway) Don't think it will leak but maybe it will get stuck - I'll get my brother to tweak the solenoid in that case...
              Mouldy I was looking at something similar to that as it regulates to my required pressure but don't know if its been tried and tested by someone else - a trevor reg at £45ish sounds like a better bet tho.
                people use Lipos in featherweights
                • #23
                  Will have a good look to your FW rules then and see if its possible to keep in line with them as well - but I really doubt we'll be able to contain the weight by that much, the frame and armour will be quite heavy, same with the drive system and flipper.
                  • #24
                    Chris:
                    http://www.youtube.com/watch?v=Wz7-mIKg ... ata_player
                    this one good
                    :P
                    i actually really like satanix dave
                    it has inspired me to make a fw like that
                    PS I'm not coming to the next a aws. its too far away
                    sorry
                    will see you in kidiminser
                    • #25
                      ok guys i will stick to ants
                      • #26
                        Have recieved a pm from Chris (liftoff) and will reply here.
                        I am about to start making some more regulators but need to finish the drive system on Meggamouse first.
                        They will sell at £75 as I am having to do them on a smaller lathe and buy all the materials.
                        I am reluctant to make fittings for paintball bottles as the rules first agreed with the FRA when I first started making them was that should only have recognised CO2 connections.
                        Chris, it would better to use the 20oz bottle for gas and the paintball bottle as a buffer tank. In the UK the event organisers supply gas and the fittings are correct for the gas. I am not comfortable with people filling non CO2 fitting bottles......remember it was not my idea to make these to sell, others keep asking for them because they are unique and designed for our specific needs.....it has snowballed from there. If someone wants to modify a Trev regulator then that is up to them.
                        Have pm,ed you Chris, and I think it is great that there are roboteers in Malta. Maybe we could all have a summer holiday, robots in the day, beers at night.....
                        Trev
                        • #27
                          Thanks Trevor, please keep me updated, I'm also asking around maybe I'll manage to find a used one as I really have to start with the build!
                          Will have a look at the 20oz bottle to see what's available and type of fittings used, have to keep in mind that I'm limited in size and weight and I'm not sure if a 20 oz bottle will fit in my setup. I have not purchased any bottles yet so I'm still free to shop around but it would be appreciated if someone could post a link to where I could get a bottle with the correct thread to fit the Tevor reg.
                          ''Maybe we could all have a summer holiday, robots in the day, beers at night.....'' You're welcome - sound like good plan :wink:
                          • #28
                            Need some advice re. armour and overall body construction. Before this build, we always used a sort of monocoque construction basically from aluminium chequer plate about 4mm thick but last year we had the body punctured by one of the competitors using a horizontal spinner so I'm thinking about adding armour to the body.
                            Don't want to go for something heavy as weight is limited to 17 kg and the flipper pneumatics are quite on the plus side I guess...so I'm looking at aluminium again. From my experience the strongest Alu available is 7075 T6, but I don't have access to a thick enough section, I was thinking something like 4mm. I found this:
                            http://www.aluminiumwarehouse.co.uk/sheet_calc.php
                            http://www.aluminiumwarehouse.co.uk/Alu ... be_(6082T6)_100_mm_x_100_mm_x_2_mm/product_info.html
                            I would have liked to add an external layer of tool steel or something similar but i cant find a thickness in the range of 2-2.5 mm so instead I'm thinking of using a power hacksaw blade like this:
                            http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 500wt_1180
                            Its made of spring steel - its hard and tough and not too expensive
                            Any advice is more than welcome :wink:
                            • #29
                              We all use hdpe- it's really good at absorbing impacts, easy to work with and is held together by wood screws, its light (about 1g/cm^3) and very few spinners can get through 15-20mm hdpe.
                              • #30
                                Well I'm thinking about that as well as it looks pretty tough and nice to work with but then I saw this on youtube :
                                http://www.youtube.com/watch?v=rW5bR4FW ... ce=message
                                and I sort of changed my mind....
