Bosch 35w wheels and attatchment
  • Bosch 35w wheels and attatchment
    How do you attach wheels to the Bosch 35w motors? I can never get a good enough look at how it's done
    Or are there specific wheels used that slot straight onto the axles?
    Finally, is there any modifications to the motors that need to be done for combat?
    Heading over to a breakers yard soon so will get some car seat motors if I can't find 35w but also getting a few other bits
    Re: Bosch 35w wheels and attatchment
    Have a look at the following for one method
    viewtopic.php?f=240&t=3503&hilit=bosch&start=120
      I think quite a few people put keyways on the shaft and attach a wheel that way.
        keyways?
          http://en.wikipedia.org/wiki/Keyway_%28engineering%29
          I do believe you can buy shafts pre cut, and the Bosch 35 has a Hex input so I'd suggest measuring up and getting on Google.
            ah, cheers pj, that looks/sounds easy enough too do
              4 mm Allen key works as a shaft too
