Re: Reliable High Discharge Lipos
540 used some dewalt motor's, not the big ones though. Very powerful but as you could see just stupidly fast. Being geared that fast reduced a huge amount of torque so by the time the magnets are on its stalling the motor's quite a lot. To get round those issues you would ideally want motor's more powerful than you need, and gear them to a sensible speed, somewhere in between the fast and low speed of what 540 had would be pretty reasonable. I usually aim for around 800-1000rpm at the wheel maximum on 75mm diameter wheels, but that's just my opinion. Any quicker and you are just stressing the motor's more than needed. If you do it this way you'll have less problems if you decide to put magnets in for extra traction.
The way you drive will massively help as well - to help get around these problems in our smaller kits as theyre running for hours is to have custom software in our speed controller's with acceleration ramping built in so that the current when changing direction is massively reduced.
						 ). David runs 6:1 on satanix with his 120mm wheels but he is only using 2 wheels not 6. The bane bots 124mm would be the wheel of choice as we can easy change the shore value of the tyre
