what is the best type of featherweight because i need a simple cheap idea and i will take onboard any idas.
what is the best featherweight
Re: what is the best featherweight
Drills would be OK,
They'd masacre HDPE, but not all robots use that.
You'd need a really thick drill piece to avoid it snapping, at least 10mm
Axes don't do much damage, they'e just for spectacle. Armours too tough.
Flippers can knock electronics out, and OOTA robots, but can be very expensive.
Rambots are a good start, as a wedge shape to rive under robots, but it would take skill to flip a robot.
Discs are best and masacre all robots, but are only run at robochallenge, and the nearest to us is London in April.
Gripping weapons again are just for spectacle, and I'd imagine heavy.
Thrackbots have electronics inside the wheels, and have a bar as a weapon, like
stinger-http://robotwars.wikia.com/wiki/Stinger
and chimera-theres a pic at the bottom-http://robotwars.wikia.com/wiki/Team_Death
The saint- can't find a pic because roaming robots is down, try googling it.
Wilhelms scream could be considered a thrackbot-again can't find the pic
And full body spinners, in which the whole body moves round the base. Again, count as a disc, so can only be run at robochalllenge
http://robotwars.wikia.com/wiki/Full-body_spinners
Using electricity and fluids etcetera is banned, so don't start building clever ideas without checking the rules first.
The matter of 'the best featherweight' or 'the best weapon type' is totally down to opinion.
Personally, I would say that the flippers are the best, and has been shown due to the majority of UK championship results (and other competitions such as the tag team). However, others have different opinions, as shown in previous posts.
Long story short, that's a matter to decide yourself. There is no set answer.
