Alternative ESC's Needed ASAP!
  • Alternative ESC's Needed ASAP!
    Hi Guys
    I have just been informed by Electronize that they will not supply me any more speed controllers after I damaged the first ones.
    What alternatives do I have to those that I can get hold of before GSL and are the same size?
    Failing that does someone have 2/3 Electronize ESC's that I could buy off them?
    Thanks In Advance!
    Re: Alternative ESC's Needed ASAP!
    Someone was selling a couple on here a while back, check the for sales.
    I think they were the 15a ones, but I don't see why they couldn't handle 2 drill motors.
      I blew a 15a fuse with my lifter's 12v drill the other day. I'd be careful running 2 gimsons on one 15a ESC.
        Mine is fitted with a 100A fuse for the lipo but that was not the problem, when I made the wiring for the lipo and the removeable link I forgot to check the polarity of the link, which was on backwards, then I put the battery into the link socket by accident meaning the battery was on backwards then put the link in and poof. Well half poof, the robot still goes forwards perfectly fine but no backwards.
          We have all made the reserved polarity mistake (or at least I have... a couple of times now....) and an expensive one it is...
          Good reason to have Fuses on your ESCs or one low enough on the Li-Po!
          Besides what do you want reverse for? That's for retreating....
            do you still have speed control or is it just full throttle, what happens when you try to reverse?
              Have they refused to supply you with any more replacements for damaged controllers, or are they refusing to sell you new ones? If they've just refused to supply you with replacements for damaged controllers, just buy new ESCs from them? If it's the latter, it seems quite frankly foolish of them to refuse business to anyone considering how difficult it is for a lot of companies to generate business right now.
                That's how I initially read it, but that can't be true.
                When I reverse polaritied my Sabertooth Dimension Engineering just sent me out a brand new one! And it as the next model up, and I bought the first one 2nd hand, most impressed with them.
                British companies could learn a thing or two about customer service.
                  They are refusing to ever sell me or anyone with the sir name Botwright ever again by the sound of it. The said that it did not seem that I knew what I was doing and that they did not want to be involved. One tiny mistake and it has put me about 1 month behind on the build :x
                  Full proportional control. So that means that the IC on the board is fine. I reckon it is one of the 2 large relays or one of the transistors that controls the relays that is bust.
                  Remember Razor series 4, got stuck in forwards and could not escape the arena wall, that I want to avoid if at all possible
                  It seems that that the Victor 883s will fit, just, so I am trying to track some down without having to order them from the US.
                    You could try replacing the relays with automotive relays, or get someone else to order some for you and forward them on.
                      What model are they? The relays are easy enough to get old of, just swap them.
                        Just de-solder the relays and replace them. Bit fidly but good soldering experience.
                        I am very surprised to hear that they are not going to supply them to you ever again. Although to be fair, i wouldn't be expecting a replacement if I reversed the polarity on a speed controller.
                          I knew that I was not going to get a replacement, I made the mistake after all, I just ordered some more and they said no
                            That's really not on. It's a simple, easy mistake to make.
                            I've heard of corporate responsibility but that's just taking it too far! He could have made 2 more sales.
                              4, I wanted spares! £174.60. No matter, I will just use Victors from now on, if i can get them before GSL. At this rate I will arrive having done 0 driving practice! If any practice at all I will be a sitting duck, then spinning debris...
