First off, Im new to pneumatics and I have found loads of information on rams but nothing on air motors. So anyone who knows a thing or two about them please help.
Ok, I want to build a vertical spinner using an air powered Cut Off Tool I found in the screwfix mag (vol 65 P247). The air motor spins at 20,000rpm at 90psi and has an average consumption of 4cfm.
How do you work out how bigger bottle of co2 I need for the length of a match, bearing in mind its continuous consumption? Would powering it off a bottle of compressed air work while its being topped up with an electric car tyre pump?
And lastly, How do you connect one up to a robot for a low pressure system, is it similar to how a ram would be connected?
Thanks
Martin
P.S. Anyone know where to get better air motors?
Thanks
Martin
