For the moment i would just put some bike tyres on then, there good and easy to do.
You can always vulk them after if you need to!
PIMPanaught runs bike tyresand he gets loads of tracton, i think proberbly more than vulk in arenas with bits of wood flakes and dusty surfaces(which is most arenas).I dont think vulk on feathers is atal as benificial as using it on heavies!!! well, atleast not unless you have all the weight nicely ballanced on 2 wheels.
hehe yer, that wud actually be a good idea, yet VERY heavy, expensive and will get torn up? actually, if you go for the harder grades, it might be well gd.
Wears off VERY quickly. They use it on metal skateparks and things like that, they need to be painted very often. And with the floor boards being as they are, getting torn to paices, there would be no point
