I was wondering becaus I am building a 10 bar flipper and the valve that I have works on 24V. Now my drillmotors are 14.4V. So I was wondering if you could overvolt them to 24V. I was also thinking about seting the screw on the electronise speedo down to 75% of the maximum power but I am still not shore If my motors wil burn out. Does anyone have experience with overvotling drillmotors??
Thanks
					Thanks
 ). If you want to overvolt to 24v, try to restrict the power going into the drill motor via the speed controller if possible, but no matter what you do with current limiting etc, you must use small wheels if you are to go to 24v. Anything over 70-80mm is too much and will strian the motors too much.
