pistol grip systems
    Re: pistol grip systems
    Anyone got an idea why electronize ESCs won't work properly with a pistol grip system (with GWS mixer and fail safes) when it works perfectly with servos? the motors just go into full forward as soon as they are activated (checked all the trims and they are fine)
      Originally posted by mr_turbulence
      I've got an ansman system, came with my ansman virus 2.0 nitro buggy... I replaced it with a dx3e though...I've also got a dx3r that I use for 360, aswell as dx6, dx5 and a dx7 lol
      Which RX are you using for those Dave?
        I would like to use a pistol grip for the drive of my bot. I like someone else to control the weapons and claw whilst i drive. I have been looking through the other threads so apologies if I'm duplicating. So what i would like to know, has anyone come across a system that i can plug a pistol grip into a conventional controller or will i have to have two separate Tx Rx in the robot? i need two channels for the drive and at least four for the other bits.
        cheers in advance for the help
          I would just use two separate radio systems, in the long run, it would probably be as expensive or cheaper, and it would give you the desired amount of channels.
