can you use normal chargers from NiHm on LiPo battery's or do you need a special charger
LiPo
Re: LiPo
Most modern day chargers that can do enough Nimh / Nicad cells can do Li-Po and have a built in balancer.
I got an iMaxB6 for £8 On ebay. Here's one for 99p..... Whether you trust it is at your own discretion.
http://www.ebay.co.uk/itm/IMax-B6-Digit ... 3f1033d919
Re: LiPo
I have been reading the rules with regards to LiPo batteries and there is one thing that I have been told a few times but doesn't appear to be in the rulebook; Metal boxes for lipos.
I have been told that Lipos have to be charged in a metal box and/or a Lipo sack, and should also be in a metal box inside the robot, or have at least a 2mm thick metal base underneath to protect the floor if the lipos go up.
Can someone clarify this ?
Re: LiPo
Thats right Dave...
the metal box for charging is redundant, those rules were drafted up before lipo sacks were easy to get hold of... get a lipo sack. There cheap enough on Ebay these days.
At tech check for people using lipos i check for the following;
2mm+ METAL base plate under the lipo + security of the lipo (I.E. It isnt cable tied to the pneumatic cylinder *cough* Mr Lear *cough*)
Secure well insulated connections within the robot + the connectors being used are sufficient to cope with the maximum current draw.
Sufficiently rated fuse on the positive side of the lipo, thats rated below the maximum discharge of the lipo.
The visual state of there lipo
The charger + balancer combo the competitor is using is suitable
The competence of the person using the equipment.
Im a bit more strict then some tech checkers when it comes to lipo's, but most of the people using them so far have enough common sense to think of all that them self.
Re: LiPo
7.8 LiPo
Lithium Polymer batteries have specific limitations and extra precautions which must be adhered to.
7.8.1 Balancers
Appropriate balancers must be provided if not part of the charger. They will be inspected during the
Technical Check. LiPo batteries should be properly balanced to prevent damage occurring to the cells.
7.8.2 Voltage Cut-out (Advisory)
The robot should be fitted with an under voltage cut-out or alarm set at or higher than the battery
manufacturer€Ÿs recommendation to prevent the batteries from becoming damaged by over discharge.
7.8.3 Fusing
A fuse rated below the maximum burst discharge of the battery must be fitted.
7.8.4 Extra Equipment
Roboteers using LiPo batteries must provide a LiPo sack.
7.8.5 Inspection
LiPo batteries must be removed from the robot, inspected and placed into a LiPo sack prior to and during
the charging process.
7.8.6 Charging
Lithium batteries must not be left unattended at any time during the charging process. Leaving batteries
unattended while charging will be considered a serious breach of pit safety and may result in you and
your robot being removed from the event.
7.8.7 Damage
LiPo batteries showing any evidence of damage or swelling must immediately be placed a LiPo sack and
removed to a safe, well-ventilated area such as outdoors.
