Hi,
Could you use a one way bearing (from a bike wheel) to make a full body spinner where the robot spins on the spot (like a melty brain robot) spinning the outer shell, then the robot could stop spinning but because of the one way bearing it would continue to spin and the robot would be free to move around the arena! As long as it spun at less than 500rpm could it then run at roaming robots and robots live events as the spinner is powered by the wheels?
