TX/RX - Failsafe - Mixing .....How do you do it?.....help
  • TX/RX - Failsafe - Mixing .....How do you do it?.....help
    All,
    I'm getting a planet 5 2.4ghz transmitter and receiver (from a firend for nothing - so can't argue) however I can't get my head around the whole failsafe idea that is required per the build rules.
    The robot has to failsafe when it looses signal, but can someone give me advice with regards to how I actually get it to do it physically.
    I will be using electronize esc x 2
    planet 5 2.4 ghz set
    I know other shave built in failafe but I don't have a clue when setting it up with a planet 5 tx, do I need to by something else like a stand alone fail safe?
    Also can someone link me to where I can get a good mixer?
    Thanks
    Billy
    Re: TX/RX - Failsafe - Mixing .....How do you do it?.....hel
    Would this mixer be ok to use with a planet 5 and electronize esc?
      Yes that's the most popular one used
        Link?
        May have to look into getting one if the half throws on our DX5 prove too restrictive.
          i just took the drual rates off my spectrum so its perminantly in high
            I have the Planet 5 transmitter/receiver combo going into that same mixer into 2x 30a Electronize speed controllers. If I run the motors and turn off the transmitter, it's not instant (takes a second or so) but it kills it. It failsafes. I didn't have to do anything other than plug them all together as you'd expect to. It works for me so it should in theory work for you. :wink:
              How do you do that?
                What he said.
                drual rates?
                I think I've heard this before and it may be a DX6 thing only.
                  so- to get the bot to failsafe using a planet 5 system you just turn the tx off? ?I take it that by doing this it complies with the build rules then?
                    Failsafing is one of those things that is a mystery.......
                    Bitza Mk1 fail safed, but I haven't the foggiest why.
                    Spinza, with a dedicated failsafe, refused to until I changed it to a ESC that didn't have one, then it did.....
                    In short, if you turn the Tx off with the throttle held on and the bot stops then your good. If not then consult then gods or something....
                      some ESC have a built in failsafe so thats why some robots failsafe with a t5 whilst others dont
                        Just got to get it up and running and then see how it goes.lol.
                          Will that gws mixer work ok then with electronize esc and planet 5 tx?
                            yes
                              thats perfect thanks
