Re: Crushers
how effective a crusher Is depends on a few things
the force the linear actuator or other exerts
the ratio between pivot points (this changes the tip force)
Shape and position of tip
-for example a tip with right angled edges will work better
-how far tip is from linac
my fw crusher was originally a linak minipak that was overvolted to 24v and in the end produced 10000n (1000kg) , however because the crusher tip isn't on the end of the linac there will only be 700kg at the claw tip (hence above)
So that's what I learnt when designing mine
I have since changed to a dewalt drill motor as the linacs motor so the motion is much quicker .
hope this helps
Alex
hope this helps
Alex
