Bang bang servo board
  • Bang bang servo board
    Anyone got a good image or guide for making one? Need it for my heavy but I figured its probably no different
    Re: Bang bang servo board
    thought you had 4qds?
    for a hw its a really bad idea, hell for fw its a bad idea
      Look at my build diary, I just posted photos of Rovers bang bang system.
        You need to scale it up for heavyweights, so instead of a servo moving a switch, you have a servo moving a switch, which turns on a relay (which might turn on a bigger relay - not too sure on the HW logistics) and you'll need two relays per side. There is probably a diagram kicking about on the net/forum somewhere but, to be honest, I can't be arsed searching for it.
          I'll have a look but as my HW will only be about 9mph, I might use it so I can go for 36v and have higher gearing
            Just meant that the basic concept is on my build thread, quite complicated to look at without properly following the wires and having a think about why it works the way it does. Connecting up a suitable relay to the version being used in Rover I assumed you would be able to handle on your own
                It's known as the MAG (Maryland Attack Group) control system (I believe) someone posted it in the old Bitza thread, or you could Google it.
                The basic change is instead of using the microswitches to turn the motors on and off you use the micro switches to turn beefy relays on and off which in turn connect to the motors.
                  http://www.rctankcombat.com/articles/speed-control/
                    That's the one, cheers Woody.
