minor tom
  • minor tom
    hello people of the internet I am starting my first featherweight after christmas and have all of the stuff i'm getting listed:
    4 12v drill motors
    1 featherweight shell from henry
    1 sheet of 12mm hdpe
    2 electronize 30a esc's
    1 park bec
    1 spektrum dx5e rx and tx
    ( thanks to haz for helping me with the decisions on which parts to use )
    thinking of making a verticle crusher if minor tom goes well
    minor tom is a rambot btw
    any advice would be appreciated
    Re: minor tom
    got verything i need for minor tom now apart from the esc which i've just ordered, i'm going to make a cardboard modelof the shell first to decide on the dimensions.
    the shell will be shaped like this:
      Re: minor tom
      what are the cut outs at the back for?
        Re: minor tom
        thats where the wheels are going to go
          Re: minor tom
          wheels that close together will make the robot hard to control
            Re: minor tom
            i'll just make the back section wider and the side bits smaller then so it's easier to control
              Re: minor tom
              from that layout im guessing your plan was to have the drill motors pointing inwards? ie the shaft is pointing inwards?
              i would defo swap this round will solve the control problems you would have with the current method
                Re: minor tom
                So have them pointing outwards and make the centre section wider and the sides thinner or just get rid of the back side parts all together ?
                  Re: minor tom
                  well if they fit in that orientation already you wont need to make anything wider just change the position of the gaps for the wheels
                    Re: minor tom
                    So just move the spaces for the wheels out further then ?
                      Re: minor tom
                      Yes, have them set further apart. As you have designed will make the thing struggle to turn, it would be a nightmare to drive. If your setup is like this:
                      (|| being the wheels and IIIII= the motors!)
                      IIIII=|| ||=IIIII
                      Then you could just flip it, to make:
                      ||=IIIII IIIII=||
                      Don't be too jealous of my artwork. :wink:
                        Re: minor tom
                        thanks, i'll just do that, and i'll try not to be jealous :wink:
                          Re: minor tom
                          create a thread in the build section and post pics of your progress and we will be able to help there with any issues you may have.
