Timing Pulleys
    Re: Timing Pulleys
    Those pulleys seem to be the same type as I use in Inertia XL.
    I use the Synchroflex T5 16mm wide ones, with the 16mm Synchroflex belts (same as those on Technobots)- seems to do the job nicely.
    I would advise against using the 10 tooth pulley for attaching to the speed 900- I had a few issues with keeping them attached as there was not a lot of material left to hold them onto the motor shaft with.
      Re: Timing Pulleys
      I found this tool to be a great help.
      http://www.sdp-si.com/cd/default.htm
      Gives you useful info like centre distances, and minimum suggested teeth of each pulley.
