Re: single stage gear reduction
The overall diamater isnt important...the PCD and tooth count is what you need to know... half the PCD of each gear... then add them together that will give you your exact distance between centre's...if you dont have a milling machine or a precise way to drill it, you might find this difficult to make...Just add a tiny bit on top of the centre distances... its better to have them further apart then too close.
Look at this link to find out the PCD of you gears when you know the tooth count;
http://hpcgears.com/newpdf/spurgears_1.0mod.pdf
