Largest spinning disc on a lightweight!
Whatever you use to move the robot will have to be fast - at a rather leisurely 1000 RPM, the robot will make a complete revolution every 60 ms.
Andrew, do you have any other source for the magnetometer idea? I have doubts that youd be able to detect the earths magnetic fields inside a metal box full of motors but it may be possible.
For simplicitys sake I would favour a dead reckoning scheme based on wheel RPM, but with additional feedback to the driver - a set of LEDs which pulse once per revolution to indicate the current heading; the driver can then provide fine control of the heading if need be.
