The pneumatic supplier I have recommend that I used an old style steel ram as it would be a lot stronger than a new aluminium one. But the problem is it ways around 6kg which I think is a lot! Are most people ok with 10bar aluminium rams? By the way the ram is 80mm bore and 160mm stroke which I might have cut down to 100mm stroke.
Sounds fairy conclusive! Do most people have cushioning on there rams or not, the pneumatic guy said it was needed to stop the ram ripping itself apart- but now I don't trust him so much!
Depends Woody. The Gravity/Cutlet system doesn't need it, the dampening is done on the heavy moving mass, the arm, what is mechanicaly seperate from the piston.
But for a classic setup -Chaos II-, it is mandatory.
However the question appears to be about a standard pneumatic ram ( double acting ) mechanically attached to the bot base and flipper arm... rather than a single acting F.P. ram with the flipper arm free to move and restrained/damped by bungee cord.
Hence ..
Cushioning is .. IMO .. a good idea.
IF Max has access to machining facilities and feels competent it may pay him to remove the return / base cushioning and thus shorten the ram.
I know I have asked before but I got 2 answers so I dint know which is correct. What length is a 20oz paintball bottle? Is it 330mm long or 238mm long?
I just received my paintball bottle and the on/off valve. Do I just put some molegrips on the old pin valve and wind it off and then screw on the new one or is loctite/araldite necessary?
Also I can't screw my Trevor regulator onto my on/off valve! When I try to screw it in the thread on the valve can't reach the thread on the regulator, do other people have this problem?
Remove with grips and I use a drop of sealing compound. when screwing in the new valve.
The Trevor regulator isn't supposed to fit a paintball valve ...the threads are different between a paintball and European CO2 cylinder.
