co2 tank
    Re: co2 tank
    oh sorry!!! heres the link to the cilinders:
    http://www.catalinacylinders.com/paintball.html
    and i know, but the 3.5 ounce tank fits purfectly into my kilobot
      Re: co2 tank
      Got one of those, but without a valve.
        Re: co2 tank
        i have just found this tank:
        http://www.rap4uk.com/product-p/9313.htm
        considering this have a on/off valve built in, im guessing it would be lighter, more compact, and is less lightly to go wrong? thanks
          Re: co2 tank
          this is my idea for the pnumatics set up, im relying on the thick piping before the solonoid valve to act as a buffer tank, and i think the CO2 tank comes with a pop of valve (i think thats what its called) but if not, i will add one in next to the dump valve, any sugestions for a pop of valve? thanks
            Re: co2 tank
            If I see the picture, that thip piping is 15mm outside as best. Means 12mm inside.
            length 300mm. Means volume 3,4 cc. Not much of a buffer.
              Re: co2 tank
              yeah but this pnumatics system is designed for a beetle, so the rams volume is very small (the bore is only about a centimeter with a 6 or 7cm stroke) so i think the piping is surfishent for a buffer tank
                Re: co2 tank
                http://www.store.justpaintball.co.uk/ai ... -disk.html
                is this a ok burst disk? thanks
                • #23
                  Re: co2 tank
                  That is a burst disk, but without any rating, so probably 195 bar.
