6-WD pusher
  • 6-WD pusher
    Hi guys,
    I'm thinking of maing a 6wd rambot, but I need a bit of help.
    Drive: 2 speed 900@24v on a 5:1 or a 10:1 ratio(drive leading to middle wheel then 30 tooth cog on each wheel and a chain going around all of them to give them drive)
    wheels: 100mm blue wheels
    ESC: 2x SyRen 25a (with fans on each)
    Battery: 24v 3300mAh NiMh
    chasis: 15mm HDPE with 4mm steel plate protection
    Lid: 3mm ali checker plate
    Scoop: either 5mm hardox or 5mm G5 Ti(if i have a the money)
    Any comments would be grately appretiated.
    Re: 6-WD pusher
    sounds good although i wouldn't recommend syren controllers. they are just single channel versions of sabretooth 2x25 so will probably not be able to handle the speed 900s at 24v. daves rambot satanix uses victor speed controllers. i dunno how many amps speed 900s draw but you'll probably want to work out how current they'll be pulling then look at acceptable speed controllers.
      Re: 6-WD pusher
      I remember David Weston telling me about Satanix running Speed 900's on drive and I think he said Victor ESC's worked best for him.
      Weight might be an issue too, I know that my front scoop is 4mm (I think) steel and is heavier than I expected it would be so covering the whole bot in that might be an issue. Considering it will presumably be fairly big (compared to something like tiny toon/satanix) to fit the 6 wheels in. But I don't know, you might manage it .
      EDIT: Ach, Jonny beat me to it
        Re: 6-WD pusher
        i think he (david weston) was talking of putting a wotty 180 in it as the victors kept breaking
          Re: 6-WD pusher
          Its the fans on Victors that break very easily. I think the Victors themselves are fine.
            Re: 6-WD pusher
            I think its a Wotty 100 he is talking about putting in it, thats a new FW speed controller by Ian Watts but was saying it is a bit on the large side, which is why I didn't go for one is Cicatrix. Its a 2 channel 50A per channel ESC.
              Re: 6-WD pusher
              do you know how much one of those costs tony? sidewinders are nice and compact but a bit ott for a feather although you could always upgrade to 4 speed 900's without changing the speedo (relentless runs this setup) or you could use dewalts and a sidewinder like 540
                Re: 6-WD pusher
                I'm not 100% on cost, I think they are £200. I have a spec sheet that Ian sent me if you want i'll forward it onto you?
                  Re: 6-WD pusher
                  sure
                    Re: 6-WD pusher
                    How big and where could I obtain such a device?
                      Re: 6-WD pusher
                      you can get them from ian watts, i beleive craig colliass has a couple so you could ask him for the dimensions
                        Re: 6-WD pusher
                        PM'ing you the spec sheet now Ceri
                          Re: 6-WD pusher
                          Ohhh and I have the dimensions too, sorry forgot they weren't on that spec sheet.
                          Its 120 x 95 x 34 mm
                            Re: 6-WD pusher
                            Thanks,I've got it. Don't think it says a great deal though.
                            Ruddy hell, that's a big speed controller! My IBC is only 135*55*30.
                              Re: 6-WD pusher
                              right,
                              I hope it will be underweight as i am using 15mm HDPE and 4mm steel(hardened for the scoop)
                              I'll proberbly run it on a 8:1 ratio
                              The ESC will either be a victor ar the SIDEWINDER!
                              I'll try to make it as small as possible
