my negative port on my relay is playing up, sometimes it works but only when i push the wires down. the positive works fine which i dont understand. the wire is connected properly to the spade connection but its still dodgy and since i have little experience with them can anyone help me since im nearly clueless?
robot market place large rc duel relay help
 Re: robot market place large rc duel relay help
 I don't understand your statement.my negative port on my relay is playing up, sometimes it works but only when i push the wires down. the positive works fine which i dont understand
 A drawing of the wiring would help.[attachment=1:3op79r3k]relay1.jpg[/attachment:3op79r3k][attachment=0:3op79r3k]relay2.jpg[/attachment:3op79r3k]
 pick one or draw your own.
 [attachment=0:335ixij7]relays.JPG[/attachment:335ixij7]Attached Files
 my set up is the first one and thats has all been wired up and is working but for some reason the negative has stopped working and i cant see why it could have
 which is ...my set up is the first one
 ..there's two negatives.the negative
 So your post makes little sense to me.
 The spade connectors going to the motor alternate between positive and negative depending on which relay is switched on.
 [attachment=0:3i65o8rw]relays4P.JPG[/attachment:3i65o8rw]Attached Files
