Were do you connect the powerlight again?
  • Were do you connect the powerlight again?
    I can't remember for the life of me were to connect the powerlight so that it's on when the bot is, I think it's in the negative cable after the link but I'm not 100% sure, anyone clarify were it goes?
    Re: Were do you connect the powerlight again?
    In series with the battery/link
      And you mean by that what?
        If you have main power terminals from your battery (that are disconnected when the link is removed) then hook it up to these.
          I still ain't sure, I've had it in the positive lone and between the positive and negative before the link and both times it's failed, Basiclly all I nee it what wire/s it goes in and were?
          (sorry if I'm being dim but its been a long day)
            Without knowing the specifics of your wiring loom, I can't advise. Do a quick diagram showing your wiring.
              It's just a basic ram bot set up. Batteries in series powering 2 esc's which go to the the motors and the esc' are connected to the receiver. I'm not even bothering trying to wire it into the weapon system and I do t know if it will work and I have had it I'm a ram bot system before
              I'm on my iPod so I can do a diagram, that's the best I can offer I'm afraid
                Parallel it up with the power leads to one of the speedos is the simplest way to ensure it will work (assuming your removable link does it's job)
                  HERE.....
                    Ah that's what I'm after, thanks guys
