tracked bots
  • #31
    Re: tracked bots
    i doubt that would work well
    • #32
      Re: tracked bots
      I know have 2 sets of cogs driven by a drill motor and then have 2 sets of chain around the cogs with bars welded to the chain
      • #33
        Re: tracked bots
        I like ben's idea more, it could actually be done
        • #34
          Re: tracked bots
          The best way to do it would be to use conveyor chain (or regular chain with plates welded on, a la Limpet) since belt systems tend to be more prone to the track coming off. They also have the advantage of being more durable, albeit heavier.
          • #35
            Re: tracked bots
            gears? sprockets?
            • #36
              Re: tracked bots
              good pic
              [attachment=0:3na4lxjh]dscn3518g.jpg[/attachment:3na4lxjh]
              • #37
                Re: tracked bots
                any videos of that bot?
                • #38
                  Re: tracked bots
                  the problem is that will give no grip on an arena floor, have you ever seen any of trax's fights?
                  • #39
                    Re: tracked bots
                    here's a couple of the improved version:
                    http://www.youtube.com/watch?v=-bDYYlpkBds
                    http://www.youtube.com/watch?v=GFogAMh9xro
                    yes you could make a system like this but why bother? even if you made the tracks from rubber i see no advantage to this design in combat robots. there's a reason why there are barely any tracked fighting robots
                    • #40
                      Re: tracked bots
                      The problem with tracks are if you dont have enough grip (ie using metal tracks) then you just end up sliding around, and all that weight in the system is wasted, if you have too much grip (ie soft rubber) then you put huge loads on your drive system, a tracked robot needs alot of power to turn. I've got a set of stainless tracks that were orignally going on Battleaxe (didn't due to time) these are similar to what 101 used, 101 and ST are probably the only competetive bots that seemed to work well, 101 had rubber pads stuck on the tracks.
