Removable link
  • Removable link
    Ok I've got 2 different voltages in my robot (12v for the drive, 18v for the lifter)
    If I used Plus (positive) on each battery that would mean I need 2 links(one for 12v, one for 18v)
    I was thinking if i put the negative(GND) as ground that would mean I could put the 2 batterys GND together,
    This would enable me to only have one link.
    The only question is: Is this allowed as I thought only positive can be the link?
    Re: Removable link
    The only down side in this set up is you will be using a common negative for both volages and if you get a short before the link you still have a live system ...two links is acceptable on the posative side on each circuit ....
    This method is likened to some Heavyweights that run Two links 1 for drive and 1 for weapons .....
      Re: Removable link
      why not just have two links?
        Re: Removable link
        yeh i would sugest you use two links, and any way it means you can have only one system working at the same time (like when you testing it)
          Re: Removable link
          can you not just use a deans connector with a wire loop as the pull/handle as your saftey ring/removable link?
          One on each positive wire from the batteries?
          billy
